Oliver fuel issues
If you have not found the problem yet, have you removed the plug from the bottom of the carburetor to see if that you have continues flow after you have a pint or so drawn. It sounds like the bowl runs dry even though have good flow at the carburetor. That would seem to be a stuck float or dirt in the float valve. I have had both.
My tractor acted the same as yours. A can of HEET fixed it. I don't use gasahol, so from time to time I need a moisture remover due to humid weather where I live.e
