354 international dies after a few minutes
I have a 354 international. It started dying after running it for a few minutes. It will restart with the choke but still acts like it's starving for gas. I have done the following. Replaced carb, added an electric fuel pump, replaced coil. I changed it to electronic ignition years ago. I even put points back in it just to see if that was the problem. It doesn't loose spark and has fuel going the carb. I even ran new fuel lines. I am stumped. Any help would be greatly appreciated.
Have you checked vent on fuel cap ? Checked for collapsing fuel line?
Is the manifold solid or does it have pin holes in it? Where did you get the replacement carburetor, China?
Is the air cleaner and breather components clean and free of debris? Mud daubers can plug up all sorts of air passages.
Dave.
Got an old oil squirt can?? Put gas in it, remove intake hose at the carb, start the tractor and when it starts to die start squirting gas in the carb. Will it continue running while you squirt gas in the carb. This will confirm it is a gas issue for sure. Does your carburetor have an electric solenoid?? Confirm it is working with the key on
