Suggestions for house cleaning
steveb414
What do you guys use for cleaning soffit,gutters and vinyl siding on gable ends. What did you use and how did you mix. I am thinking I'll soak sections and go back with pressure washer to rinse. Suggestions Please Thanks Steve
Product called Wet and Forget. Mix in sprayer. Wet siding with it and do what label says. Forget it. I try to spray the house when there will be a week of dry weather. Works great for me. No pressure washing needed.
Wet and Forget here also. Mix 5 to 1 like the label states. I spray with a back pack sprayer.
I use a mixture of vinegar, laundry soap, nnalert and span, bleach and water. I powerwash siding first, then brush on solution, then rinse with power washer.
We used s foam cannon on the power washer. IIRC the soap was a generic car wash liquid from Amazon. Foamed up a big section, let er soak a short, and rinsed right off. It even takes off the sap from a pine tree.
I was quite happy with simple green last spring when doing ours but it is all painted wood. On our other house we always used the Zep pressure washer soap on the vinyl.
I will say cleaning a house is new to me. I have never seen anyone ever wash the outside of there house in 54 years. Gutters were cleaned only if you had trees hanging over the house. When I read about mold on vinyl siding I must assume you guys live in a different climate than me. Never seen mold on vinyl siding.
Welcome to the south. Land of humidity.
Meet the bio-degradable plastics mandated by "you know who".
The same thing applies to house wiring and autos too. There was a house up the road that sat empty for a few years. A friend bought the farm and was going to rent the house. Guess what? All the insulation was eaten off the wires by mice and such. They tore it down. The same thing happened to a fellows camper. My house has wiring that was put in there when electricity was introduced to rural areas. No problem. It is petroleum based insulation.
