Any easy way to remove old grease??
Brian Ski
This old Farmall H has grease built up on the front wheels and underbody. The grease is so old and dry it is like concrete. I tried some scraping but it is quite tough. Was thinking of leaving it for my Son to mess with. If he wants too.
Actually, there is a lot of ways, power wash 2-3 times, scape & spay degreaser, 4"inch wire wheel wear welding gloves & helmet with face shield. The oil & grease threw time dries with field dust and gets pretty tough. It's all part of that great world of working on restoring tractors.
I have a 1940 H in the shop right now and it's has been the worst for old grease build up, doing some mechanical repairs before painting.
Some pressure washer pumps will not tolerate hot water.
I hate to use cold water... I looked and mine was rated for up to 122F. I looked around and found a thermostatic valve for $25. You hook it to hot and cold, then dial in the temp. Will give it a try to keep it within the temp range. That should make the hot water last longer too. Better than using 55 degree water.... Thanks
