D15 oil pressure
Jpsepp123!
D15 series 2 no oil pressure. Did an inframe and before I put the plugs in tried spinning it over but cant build any pressure. It is trying to pump but if I put my finger over the oil gauge fitting nothing? I am hearing there is supposed to be a stand pipe in the oil filter housing? It currently does not have one. This is a spin on base. Any help is greatly appreciated.
D15 series II should use an AC 70237000 filter which crosses to a WIX 51515, which is used by a number of Ford engines. That filter does not require a standpipe. That is supposed to be a full flow oil system
The bypass oil system filters (such as used in D14s, CAs, Bs) required the standpipe. Those filters thread at the outside of the base. not on a threaded adapter in the center of the filter base.
After doing a little digging we are going to start it and see if it builds pressure running. We dont thinks its spinning fast enough with the starter to build pressure. thoughts?
Did you do anything with the oil pump and/or pick up tube/screen? Take it off, take it apart, check it over, clean it, prime it, etc, etc? When I used to work on engines I liked to crank them over without spark plugs or injectors until I saw oil flow and/or pressure. I don't remember that ever being a problem. Something doesn't seem right.
Yes we cranked it with the starter it will pump oil to the filter but not build any pressure. We did not do anything with the pump. Pick up screen is clean
If it pumps oil to the filter base with the starter, start the engine !! It had oil pressure before you in-framed it. There's no reason it shouldn't have oil pressure now. Starter speed may not be enough. You have to fill the filter full before there will ever be any oil pressure. Start the engine.
If you don't need the throttle shaft (unique to a D-15 S2) a kit from a series 4 D-17 (TSX871?? )is pretty much identical. Don't mess with any jetting and you'll be fine. I have two numbers for the D-15 S2.....TSX863 and TSX869.
