Anchoring Sliding Doors To The Ground
Bill VA
Those of you that have pairs (L & R) do doors covering a barn opening, how are you anchoring the seam between the two doors when closed to keep the wind from pushing them inward at the bottom?
Any pics of your arrangement?
How big of an opening are your doors covering?
Any info is appreciated!
Mine are in a channel. The bottom of the doors are against the concrete barn floor on the inside and a concrete apron on the outside. It's dark out so a picture would have to wait until tomorrow.
If I remember right the opening is 12x12.
I drilled a hole in the concrete and have a rod that slides down.
Has withstood 70 mph winds.
Our old bank barn was the same as my Dads barn 18 miles apart had a cement mound in the center of the opening and one at each end. The mounds were flat on the back to make a channel for the door to slide thru. They had a round taper down to the approach on three sides.
I was told that when they poured the cement approach against the barn, they stuck horseshoe in the cement and formed the mounds later. Both barns were built when horses backed wagons in the barns and would stratal the center mound.
Not a barn so doors are not as big and these are on hinges but this is pretty simple. I put the 2x4 across when gone and drop the anchor rods when open and closed. You could have some healthy drop anchors on the outside if the inside doesn't have the room.
The answer to this is highly dependent on if the building has another exit point as to whether the doors can be latched from the inside or not.
One of the equipment buildings I had was a gravel floor and approach apron. I drove a 1" SCH40 pipe about 4 feet into the ground at a point where the two sliders met, and used a home-brew surface bolt using a 1/2" pipe as the pin to drop into the in-ground pipe and take the sway out. The sunken pipe needed to be cleaned out twice that I remember, but a cut-off garden hose fit right into it and flushed all the junk out pretty well.
Check with some pole barn builders to see what they use in your area. They might sell those door brackets. The welded center brackets we had were made from formed 1 inch diameter rods anchored in concrete. The rods had enough clearance underneath the bars to chip out packed dirt, ice and packed snow that eventually accumulates.
A pipe, angle iron or channel iron bolted to the doors can reduce flexing in high winds.
Similar set up here.
I have a hole in the 10'x10'concrete pad in front of the doors. I put a plate on the front of one door and in the space between the plate and door, I have a piece of "3 rebar easily dropped in place and removed. Doors are male and female where they meet with a latch half way up that locks them in place, with additional latches to the walls on both doors on the other side.
If on concrete do as richardG did. Only thing different is I put a 1 inch pipe into the concrete with a sledge hammer after drilling the hole. then I tapered the the pin so it always finds the hole when the floor and doors shift a bit. If in the ground I have taken 2-3 ft of pipe and pound in the ground and do the same. Use a drill bit once a year to clean out the pipe.
Dad put a concrete apron with a channel in it on all the wood doors. Works great except in winter when snow and ice freeze in, then it’s miserable.
Some do just a ledge of concrete (better if embedded angle iron) on the back (inside) side, an inch or 2 lip. Small hump in the middle on the outside where the doors meet. Doesn’t freeze down as much as it’s not a channel, just a lip.
Lot have a small I beam in the middle for the doors to slide over and around. It pins both doors down. Pain in the rear to drive over. Some are on a post that slips into a hole in the ground, but that can get tough to pull out with rust or dirt or frozen. And then the bother of taking out and putting back in.
Folk have made a pretty good size pipe cut in half, put in front and behind the middle seam as a guide the doors sit in. Make a short 18 inch channel basically of half pipe easy to drive over.
Lot of good examples of a pipe or rod to fit down into a hole inside the doors here.
Paul
Put a drop rod on the doors & bury a couple, couple foot lengths of pipe in the ground under them. Could probably poke the holes in the ground with a long enough bulb auger on your favorite drill.
Mike
