Centerplate
- Location
- Green County Wi
I planted about 20 acres of cover crop rye. It is an 1850 with a dot 4 Perkins. I did not take a picture.
Nick, did you have a good harvest there? Bailey is almost done with soybeans, green leaves hanging on yet... GG WesI planted about 20 acres of cover crop rye. It is an 1850 with a dot 4 Perkins. I did not take a picture.
That's just a neat looking machine. I always love to see those pictures of units that have been loved! Glad for you. GG WesDrained the gas tank on the ‘49 77 in preparation for its long winters nap.
Will also be putting a battery maintainer on it before things get too cold, which may be a ways off considering how things have been going this Fall.
Thank you.That's just a neat looking machine. I always love to see those pictures of units that have been loved! Glad for you. GG Wes
Not that my 88 needs a lot but wish I could give it all the TLC that you are giving your 77.With the help of my local mechanic, we got the front main seal in, timing gear cover, governor and water pump back on.
Transmission bearings, new upper main shaft and belt pulley delete parts back on.
New manifolds.
New rear main seal and pilot bearing are in. Got the flywheel on but found that the bolts were stretching as the were tightened so that is on hold until I get new, harder bolts.
That’ a novel idea for the dealer style sticker
I meant Oliver Haven and your town and name.Just what Oliver put on the 2255's
