Mule Meat
My 8N Ford's,so far? I'm ok...so far.
I still enjoy each and every one.
How you guys doing?
On the 8N. Try this.
Put it in Natural
Pull up on the shifter
Swing the shifter to the right
One of Fords little safety secrets on those tractors.. Makes getting on and off easier by not having to climb or throw your leg over the shifter. It also prevents you from kicking it into gear when you get on and off while the engine is running.
An old guy showed me that trick when I was about 12 years old in the 1970's.
It may be a little hard the first few times if you haven't ever did it on your tractor. A little lube and it will become easy to do.
