1650 Gas to diesel pitfalls
deene
Hi, i have a nice later model 1650 with the 3 spd. its gas and needs an engine kit which is close to $1200 without valve work or anything else. I would do the engine myself. I have a chance to buy a running diesel 265 out of an 880, cheaper than the rebuild kit from this site. Which way is best to go, offset price in gas vs diesel isnt to bad as it just gets used as a chore tractor, is this a bolt in? What caused the hp difference between the 2, just head or rpm? Thanks for suggestions
Yes its a bolt in, but personally I wouldnt go with the 880 diesel engine unless I knew it was in super good shape, especialy if it has the Bosch pump which is pretty much impossible to get parts for. If your tractor was a diesel it would have come with the 283 direct injection as you stated it is later model. The 283 direct engines are a quite a bit more advanced than the 880 with the old lanova indirect, so really no comparison. As far as comparing the 880 gas to 1650 gas I believe compression ratio was a bit higher on the 1650, valves both intake and exhaust are slightly bigger, cam profile may be different, and yes RPM went way up, other than that I dont think there would be a whole lot of difference when comparing the Gas motors. Just a suggestion, but if you rebuild your existing engine , you could go with a set of 3 7/8 liners and pistons which would liven her up a bit. If using as a chore tractor and you live in a colder climate there is no doubt your gas will start much better in the winter? Also you will be keeping tractor original if that matters to you at all? Anyways what I would do is tear down the gas engine to see what it needs before you decide? Ya you can get into a pile of $ if you have to get crank ground, new valves and seats, rods resized, bearings are a crazy price etc etc. BUT at the end of it you will know what you have. You say its a nice later model with the 3 speed so probably well worth spending 3 or 4 grand on the rebuild?? The later 1650, 1655, and 2-70 Whites are sure hard to beat for a lot of jobs on a small farm.
Just to throw in another factor. Unless that upper end of that 265 is in tip top shape with really good compression, you are not going to like trying to get it started and warmed up if it sees much use in the winter.
Rated RPM and PTO RPM of the 1650 is about 25 percent higher than the 880 engine, 2200 RPM vrs 1750 RPM on an 880. That would be OK for drawbar work but might be a problem for PTO work. No load fast idle speeds are 2425 RPM for the 1650 vrs 2000 RPM for the 880. Sounds like the 880 engine will never get the 1650 up to full PTO speed (2200 RPM) without governor work and maybe some cam and cylinder head work as well.
Compare your fuel prices for off-road diesel and off-road gasoline. Until diesel fuel prices return to much closer to gasoline prices, the gasoline engine might be cheaper to operate .
Thanks for this advice. the cost of the kit just pistons and rings is what made me look at the 880 engine. i will probably just rebuild whats in it and go from there. The tractor is straight with all new rubber so would be worth the investment.
I agree with Tom go with the 3 7/8 kit. Did that on my early 1650 gas and helped a lot with power. I have both 1650 and 1655 gas tractors and the 1650 with 3 7/8 kit has a lot more snap to it than the 1655 with out. If 1655 ever gets overhauled it will be with 3 7/8 kit. The 3 speed is nice in the 1655
I have never run a 3 spd, only the 2 spd so kinda anxious to get it going. thanks for the reply
Yes i have read about the cold startup issues. Thanks for your reply
Yeah i was looking at price differences, but the gas engines seem to really like gas..lol I do like the way they start better when cold though, the issue is that the premium gas is up there as well, its the only thing that seems to help with not deteriorating the viton tips on the needles in the carb.
