I'm getting older.... Ease of getting on and off my tractors.
My 8N Ford's,so far? I'm ok...so far.
I still enjoy each and every one.
How you guys doing?
On the 8N. Try this.
Put it in Natural
Pull up on the shifter
Swing the shifter to the right
One of Fords little safety secrets on those tractors.. Makes getting on and off easier by not having to climb or throw your leg over the shifter. It also prevents you from kicking it into gear when you get on and off while the engine is running.
An old guy showed me that trick when I was about 12 years old in the 1970's.
It may be a little hard the first few times if you haven't ever did it on your tractor. A little lube and it will become easy to do.
Put it in Natural
Does that work with the older three speeds in the 9 & 2N?
Mike
I put an extra step on my Case VAC and am going to put some on my 8N's.
Kubota L5030 is not too bad and John Deere H is OK.
I am 74 and hope to use my tractors at least 10 more years.
Maybe 15.
Modern trucks are tough!
I'm 86 at the age where it's furniture surfing good part of the day. I lost count of how many tractors I have. The easiest is my JD 4300 the hardest are the small utility tractors like the MF 210 and 220. I have 730 and 930 case and doesn't seem to be a problem. The monster I just bought a Case Construction king 480 F with 4 in one loader and backhoe seems to be alittle tricky with a step up brace on one side. I guess that's what keeps me moving and alive.
When I got my Minneapolis Moline 445, I noticed that the step was pretty high also. I found some steps at a swap meet and had them reworked to fit. They work great!
Mike
My 2N does not let me do that. Afaik, that trick only works on 8Ns. On the plus side, it's still no problem for me to get on and off it without that extra help.
My WD would probably be a problem for me now if I didn't have 3 point arms or a drawbar for that first step, then up to the flat plate, one more minor step and you're on - but I've never used it without either the 3 point or the drawbar installed. I still have to start it standing on the ground on the side - the fancy linkage that lets you push the starter button while seated on the tractor has been gone for ages now, sad to say. Makes it very important to be sure trans is in neutral and hand clutch is disengaged.
I'm wondering if those having issues getting on/off a Ford 8N don't have running boards?. It occurred to me that mine were added by someone after the fact, and that they're not standard equipment on a 9 or a 2, but I thought 8Ns came with them.
The bottom step on my 1066 with a Hiniker cab is a tall step for me, being that I'm not very tall. I'd like to add a step. My Hydro 70 with a YAR cab isn't bad, but the door seems to be getting more narrow all the time! The 3 Ms aren't much fun to climb on from the back, but still doable. A step between the drawbar hoop and axle housing would be nice though.
Yeah ? I'm stiff .. sometimes painful to get on and off.
I guess we all will suffer this issue, sooner or later.
My big JD tractor is a tuffy to get myself up in the cab..
My New Holland TN60A 4x4 is not as bad.. I still struggle a little bit.
My Belarus 250as is tricky...
How you guys doing?
Yup. My 806 with the org one step has become a huge issue even with the home made second step is not much help . SOOOOO i guess am going to have to invest in the STAIR CASE with hand rail along with the fourth step. and hope i don't plant it and end up ripping it off/
I was doing a pull up with a hand on the steering wheel on my Case 300 too until a few weeks ago when I ruptured a quad tendon doing that. Looks like I will have to figure out some sort of step for it now.
I put a new steering wheel on my Oliver 500 (David Brown 850) when I restored it. A couple of years ago, I was pulling myself up on to it by the steering wheel and it broke a spoke. You'd think no big deal, but there was no steel rod in it, anywhere. It was all plastic. It sure looked pretty until then. I had to put the old wheel back on it.
My father had put these steps and railing on at some point. When I inherited the tractor from him, I thought “I’m still young enough (@65)to use the original step”, which he had kept. So I changed them but am holding onto the steps with the handrail, knowing it will only be a matter of time until I put them back on!
What need more is to devise some kind of fold-down platform I can step up onto to pour 5 gal cans of fuel from, instead of a step ladder.
Look for one of those battery powered fuel pumps. I bought one that runs on Dewalt batteries. No more climbing up with the can, just pull the trigger on the pump. They cheap on Amazon.
OTJ
How you guys doing?
I bought a Kubota M7040 with a loader 2(?) yrs ago, and quickly installed a hydraulic SSQA release and lock system for the loader. I routinely swap the hay spear for the loader bucker, or the manure pusher/front blade, and back again, all in a short time. Saves a lot of climbing on and off the tractor. Mark.
Try owning a Corvette. One can fall into it and hope you don't get hurt on the way down. Then have a team of mules handy to pull you out! 🤢
I had a Lincoln MKZ that was almost that low, and that was 10 yrs ago. I couldn't get out of it today. This tractor was designed to be easy to mount and get off of..
Couple of years ago, I rebuilt the engine on friends late 30's JD L.
When we got it back together, I learned there was no way in hell to get on and off that thing.
Tried to figure out a way to put steps on it.
Never could figure it out.
After driving it around, I thought I would never get off the thing.
I need a step on my 40S for sure. It's small, narrow running boards make manipulating my big feet around and over the transmission difficult. If it was not my Grandaddy's tractor I doubt it would still be here. I have a step on my Allis C, but it is too small for me.
Maybe 15.
I have put steps on all my tractors that didn't have one. May have to add a second one on some if my knees get any sorer. Damn Arthur is getting the best of me and my wife. 👨‍🌾🦯
