2005 Silverado battery mystery
One more thing to keep in mind now that I think of it is the security system on the ignition. I'm kind of doubtful that GM used chip keys in 2005, but if they did and if your chip wasn't reading, that would cause those exact symptoms (acts just like a bad starter/solenoid).
But I'm thinking that GM used their stupid 'Passlock' ignition cylinders they used on smaller trucks and SUV's, which was also known to cause grief. I had a little 2007 Colorado for a while and it had issues with that system, which caused the same symptoms. But if I remember right, when it was causing starting grief, the little key/padlock light on the dash would also come on to say that it wasn't registering the passlock thing correctly. I'm assuming that GM used the same system in 2005. If it is the 'passlock' system, it might be an easy fix. On my '07 Colorado it was just a wire you cut under the dash to disable that system permanently.
But if the security/lock light isn't coming on for you, then that's probably not the issue. I'm still inclined to suspect the starter, given the age.
I would check fuse first, but likely starter. I had the same thing happen on my 2017. I thought battery as it was cranking kinda slow, but then one morning nothing. Got starter from GM dealer as only few dollars more than Canadian Tire and is a new starter not rebuilt.
Lucky you don't have a dealer that rips you off like the ones around here do. Couple families own all the car dealerships. 👨‍🌾
Sure doesn't hurt of cost anything to clean all battery cable connections including the ground.
Lots of folks overlook that important feature.....especially when you have a cast iron main frame, galvanized battery connecting wire tip and steel bolt, all 30 years old and dissimilar metals with current flowing through them...corrosion personified......having never had any attempting payed to them. Problem is on both ends....battery to the main frame on one side under a steel bolt, and lug on the case of the cast iron starter case held in place with a steel starter mounting bolt.
The starters I know of have a small wire going to the solenoid. With the key in the start position measure the voltage on that wire at the starter to the starter frame if you can get to it. If none trace it back. That should eliminate the starter. If you do have voltage the starter solenoid should at least click. If it doesn't the solenoid may be bad. If it clicks check the voltage on the main hot cable to the starter frame. No voltage or voltage drops drastically check the cable. If it clicks and you have voltage on the main starter lug, but it doesn't turn over check the ground connection. Probably the next step would be starter replacement.
Could be as simple as a bad stretch of cable, internal resistance, even if all the connections are clean. You can check that with a VOM. Attach the leads to each end of the cable according to the polarity and hit the starter. If the meter shows more that 0.5 volts the resistance is high. You're actually setting up a parallel circuit through the meter and if the resistance in the cable is high it throws more voltage to the meter.
All this GM starter talk reminds me of a drag racing story. I pulled up to the ticket both and my 74 big block truck would not restart. Someone pulled my rig into a spot, and I unloaded my VEGA and started running time runs. When I got back someone had pulled the starter and wanted to know if I had a spare. Of course, I had a spare, I was driving a 454 Chevrolet. It was behind the seat with the spare HEI. When I got back from the second run a friend had disassembled the spare and rebuild it correctly. When I got back from my third pass the truck was good to go. I miss those guys.
Good evening:
My 2005 Chevy Silverado "LS"seems to have an electrical problem. I have been using it normally around town for months, parked in garage nightly. Then yesterday, It would not start when I turned the key. Lights like dome light, dash panel, headlights came on normally when I got in, but when I turned the key, no starter! Battery was about 6 years old, so I took battery to O'Reillys, they said it was bad. Installed a new battery, symptoms still same. Incedental stuff comes on when I get in, but turning key does not activate starter. Also, I note on dash a little red image of a battery lights up.
. Anybody who can fix this will tow it to their shop, so there goes $85.00 or so. Suggestions welcome....
I am actually VERY surprised at how many guys said to ' just replace the starter'. And then when someone's tractor won't start: 'diagnose first-then replace parts'. There were several good suggestions on diagnosing however, and that's where to start. Mark.
When last did you replace the battery cables? The terminals can corrode inside and insulate the terminal. Also the copper cable will corrode under the insulation and cause high resistance.
Your battery is never ok when you take it to a parts store. You always need a new one.
I invested in a very inexpensive variable, inexpensive HF load test set where I could subject a battery to put out at least 300 amps. I usually fully charged the battery and then hooked the load tester to it and cranked up the amperes...decreased the resistance of the load in the test set. I usually ran the current up to at least 200 and if good on up to 300 looking at the battery terminal voltage......If I didn't get at least 10 volts on the meter, time for a new battery......the test set was cheaper than the cost of a new battery for a truck or tractor.
2013 Silverado worked fine up to one Sunday 5 wks ago. No starter action as above. Power at starter, but no go. Son brought a new starter home from work on Monday and changed it out in 20 minutes. Problem solved.
