1965 JD1010W no spark
JD1010W
I'm stumped. I have a 1965 JD1010W tractor. In 2018 I installed a PerTronix ignitor to convert it to electronic ignition and it has operated flawlessly until this fall. A few weeks ago I did some yard work with the tractor then moved it to its winter resting place. At that time, the engine suddenly stopped and would not restart. Using an inline spark testing light I found no spark to any of the cylinders. Upon replacing the rotor (slightly corroded) and the distributor cap (corroded center button) I experienced the same result of no spark. The ignition coil appears to have proper resistance when disconnected. The 12V battery reads 12.6V at the terminals, but only 11.4V at the coil wires (is this a problem?). My operator's manual says to polarize the generator before attempting to start by touching a wire to both the GEN and BAT terminals of the regulator, but I honestly don't know where the regulator is or what it looks like.
Any insight is much appreciated. I would hate to let this sit all winter without isolating the problem.
In what situation does the operating manual tell you to do this process? That process may be helpful if you had the tractor setting a year without the battery hooked up or have changed the regulator or generator. In regards to your problem the generator/charging system has nothing to do with the loss of spark from your ignition. In most cases if the battery has enough power to crank the engine the ignition generally will be able to produce a spark. I am not sure if a meter can perform this test but the terminal that connects to the coil from distributor which should be the (-) terminal should have alternating on/off power(test light flashing) during cranking. Negative terminal is based on if the electrical system is negative ground. If you don’t see the on/off at the coil your Pertronix module has very likely decided to fail on you.
Thank you used red MN. The manual says to polarize the generator whenever the battery has been disconnected but I have never done that in 20 years with this tractor. I don't think I have the right tools to do the test you recommend at the coil, but I'll see if I can do something with the multimeter. Is there a specific process to test the Pertronix module?
Basically what I described is an easy initial test. Any auto parts store or Walmart will have a 12 volt automotive test light to perform this check.
Edit to add: Check that the distributor shaft is actually turning when the engine is cranking. On rare occasions a gear can strip or a drive pin can fall out or shear.
Do you know the model of the Pertronix module you have, you will likely need that. The JD 1010 used Wico, Prestolite, and Delco Remy distributors. Which one does your 1010 have? With the module number you should be able to find the installation instruction sheet on their website and review the wiring diagram and troubleshooting info on the instruction sheet. If you can find the module number the distributor make and model should get you the recommended modules so you can look at those instruction sheets.
I believe Pertronix will talk with people about trouble shooting, that call during regular business hours.
As used red MN posted the generator should have nothing to do with your ignition working, given the battery voltage you posted. If it was charging when it quit, it is doubtful it needs to be polarized now.
Yes, I have the PerTronix 1544 for the Prestolite distributor IBT 4101 U 10G. I reviewed the instruction sheet but there wasn't much on troubleshooting. As I said this was a sudden loss of spark so I suspected a loose wire or a failure of the ignitor. I will get a 12V test light and also check that the rotor actually turns.
