801 or 861 Powermaster
Tom Bond
I've made the deal to purchase this tractor. It's been repainted, new tires and fixed up nicely. Being delivered this weekend. The current owner says the serial # is from an 861 but it has 801 decals? It does have a 5 speed and live PTO. Does this make it an 861?
Thank You!
Yes it is an 861 as opposed to 841 851 871 881, or various others. Your IT manual when it comes will teel all the different combinations.
801 is the series. All 801 tractors were made from 1957-1962 and had either the 172 gas, diesel or LP engine and the heavier (than the 601 series) rear axle.
821, 831, 841, 851, 861, 871 & 881 are the specific model numbers within the 801 series based on the transmission, PTO and 3 point options that it left the factory with. All 861s are 801s, but not all 801s are 861s.
The serial number has nothing to do with what model it is. The factory used the same serial number range for all tractors that left that factory in a specific time range, so one serial number might be on a 621 tractor, and the next sequential serial number might be on a 871 tractor.
There are 2 numbers stamped on the flat spot behind the starter, one is the serial number and the other is the model number. If it is an 861, then the model number should say 861.
very nice
pretty good detailing on the paint/not painted stuff
yes, it looks like a model 861 of the 801 series
If it was mine, only thing I'd change right away
is that rubber gas line that snakes up by the manifold front.
If you don't want to mess with the sediment bowl, and tank
fittings, just cut/bend steel line to fit and use very short rubber hose
junctions, or compression fittings.
Real nice tractor Tom.I like the Powermaster series.
There's red paint on the exhaust right in front of the alternator pulley.Is it rubbing there(I know there's not much clearance there).I just "shoe horned" that same pipe into my 1841 yesterday.
I see there's paint above the pulley on the exhaust also.Maybe it's just from the "wrestling match" of getting in place.
Good Luck, GT65
From the photos, it appears to be an 851, though it is not possible to determine definitively.
Are you sure that it has live PTO?
Nice looking machine.
Dean
It looks to me like the clevis fork on the clutch rod has the pin through the forward hole which allows the clutch pedal to drop down.
I agree, and Id run the gas line around the front instead of over the top and behind the manifold. It runs cooler, and has less tendency to boil the gas.
I forgot to mention thats one fine looking tractor, and one of the best in the ford lineup as far as Im concerned. It might suck a little gas, but it is in a whole new leaque compared to the 600s and earlier.
while a 55+ hub is shown, it appears to be the earlier one with out the raised spots liek the later hub has. though i guess could be an early 801..e tc..
I agree about the low level of the clutch pedal.
wonder what the tranny model number says...
soundguy
Nice tractor. Looks like an early one as the left brake shaft goes
through the clutch housing in front of the tranny as opposed to
under the transmission on tabs. Not an expert though.
Jason
like the guys said, if you move the pin on the linkage to the rear
hole, your 2-stage clutch/live PTO will be enabled.
bad thing is it makes your clutch pedal almost straight up.
If you aren't using PTO implements that need 'live' PTO,
it's fine like it is, much easier on your leg to drive.
equally nice 860 with PS-remotes-nice tires-paint
at my local auction Sat.
very pretty......I better stay home......
I have a book that breaks down the serial number into year. also if you look on the tractor just under the oil/ air filter there is a flat spot that will have the model number. I have the same tractor. yours looks to either be a 851 or 861. the pto makes the difference. and that tractor was made for 57" to 62". im guessing yours is 58" or 59" but if you give me the serial number i can tell you
