1105 massey
Cannonplay
The lift arms only work when I turn the steering wheel and they fall unless I continue to cut the wheels hard. The lift is strong
Also the remote doesnt work. Ive replaced thr charge pump.
Weve also had the hydronic pump ( that sits behind the radiator )
Tested and Im told its not the problem.
Does anyone know from experience what the problem is?
I don't know if it's related or not, but I had a 1020 Deere that did that exact same thing with the loader. It only worked with the
steering wheel turned all the way right to the stop. One of the spools in the power steering was blown.
There is a priority valve on the front of the firewall. Hooks the
the steel line from the pump. I would start there.
(quoted from post at 05:14:44 09/12/21) The lift arms only work when I turn the steering wheel and they fall unless I continue to cut the wheels hard. The lift is strong
