My 1175 steers harder than I think it should. Not terrible but at idle it is very hard to steer when it is warmed up. When its cold it turns the same at idle as it does full throttle. When the oil is warm at idle when you turn the wheel there is a whining sound that to me sounds like the pressure relief valve opening up. When you rev it that sound goes away and the tractor turns better. I checked the pressure coming out of the relief valve a while back and I dont remember the pressure but it seemed to be ok. I have rebuilt the steering cylinders so there shouldnt be any problems there. Im planning on replacing the hand pump this winter because I believe its worn out causing the stiff steering and the pressure relief valve opening. Any thoughts on this is appreciated. Thanks
