12 volt coil help
jm.
Location
Dover TN
OK I know this is going to draw all kind of answers so let me explain why I need the answer first. I already searched the board and know the answer is on here but have not found it. I am working on a international scout. This thing was running perfect (little four cylinder) and I started down the drive and it backfired, took it to two different mechanics no luck so I found a rusty one with same engine that had sit up for a couple of years. These scout come from the factor with early electronic ignition much like Petronics. I could never get to changing the engine so hired a young man and when he traded the engine he converted the engine back to standard ignition with points. Brought it back to me and it ran perfect off the trailer. Two days latter I start it and all kind of backfiring, OK bad gas, no good gas, ok points stuck new points, checked timing , been on it three days, removed the coil and it says NO EXTERNAL RESISTER required. So off to auto zone, they have one that says the same thing but it is marked 6 volts, he hands me one that has no marking on it and says this is what you need. I want to know what the restience should read on a 12 volt coil that does NOT use an external resister. Hate to burn up the points. Thanks in advance for reading this long post.
Coil resistance for a coil that runs on a 6 volt system (about 7 volts when in use because of charging) should have about 1.7 to 2.1 ohms. That coil can also be used on a 12v system (at 14 volts because of charging) with a ballast resistor of about 2 ohms. A 12v coil for use with no resistor will measure about 3.5 to 4.2 ohms. These measurements are out of circuit, from small terminal to small terminal. Jim
You ask "I want to know what the restience should read on a 12 volt coil that does NOT use an external resister"
A full true 12 volt coil that uses no external ballast "typically" would have in the range of 2.5 to 4 ohms, many around 3 ohms average. Reason being its best if the points aren't switching much over 4 amps so 12 Volts/3 Ohms = 4 Amps
A coil labeled "12 Volts" or one labeled "12 Volts not for use with (or no ballast required) ballast resistor" is a typical full true 12 Volt Coil and would be in the 2.5 to near 4 ohms range...?...
A coil labeled " 12 Volts for use with ballast resistor" is more like a 6 volt coil in which on a 12 volt tractor the ballast drops 6 volts leaving 6 for the coil.
Some 12 volt cars n truck n tractors used a 6 volt coil PLUS an external series voltage dropping (12 down to 6) ballast resistor. Some had a ballast by pass when cranking scheme to improve cold weather starting
Does it have a ballast (typically 1.2 to near 2 ohms) or not ???????????? if so and its good and works YOU NEED A 6 VOLT COIL. A ballast PLUS a 12 volt coil would give a weak spark !!!!!!!!!!!!!!!!
Most typical causes of no fire are oil or film (some new points have protective coat that needs cleaned/removed) or oxide coated or burned pitted points ALWAYS CHECK POINTS FIRST and insure clean n dry no oxide coating or film or oil and gapped correct. A bad condenser can also cause ignition problems !!!!!!!!!!!!!! Sure the old one is ok ?? Many new out of the box are bad while the old originals are still fine ??? See my Troubleshooting Procedure below
If you need more detailed ignition troubleshooting click my link below
You may get several responses and opinions as its an electrical question, here's my response TO YOUR SPECIFIC QUESTION maybe others have different answers
John T
John Ts Ignition Troubleshooting
Thanks Jim , I was thinking of asking you direct because thought you were the one that commented on the resistance the other day. Looks to me like Auto Zone Durlast c 819 is not what I need.. Thanks again.
With a 12 volt system that runs from 9 volts when cranking up tp 15 volts when running? Total primary resistance with points ignition is around 4 ohms. You can have a 2 ohm coil fed by 2 ohm resistor. Or a very common 2.2 ohm coil with a 1.8 ohm resistor. Or for the coils sold for 12 volt systems with "no external resistor needed" there is a fixed 4 ohm resistance in the coil primary. They ALL work fine. Just a matter of how you prefer to do it.
Have over 8 of them and none here have an EXTERNAL resister, not to say the wire feeding the coil is not set up to provide the resistance,, all I have had the small electronic box powering the petronix type ignition. Probably going to try a new device that is on the market that all the ignition is in the distributor. All one has to do is supply 12 volts to the distributor. Unit called a DUI unit.
I just looked in my old IH Truck service manuals. They only showed conventional ignition system with points in two different styles of distributors. On those the resistance would most likely have been in the form of a resistance wire in harness between ign switch and the ignition terminal on the starter solenoid.
If your starter solenoid has two small terminals, and one of them has a double wire, then you have a resistance wire if you have no external ballast resistor in view near the coil.
Apparently your scouts are newer than any I worked on if they have electronic ignition but I would bet they still utilize the resistance wire bypass system for starting purposes.
Good morning jm, to add to my post below heres yet more info. I just cant say from here if your truck had originally or was modified to a full true 12 volt coil (NO Ballast required) orrrrrrrrr it uses a 6 volt coil in series with a voltage dropping (12 down to 6) ballast resistor ??????????? You need to determine that if you're going to replace the coil. Also the ballast could be in the form of a resistive wire (may be hard for a rookie to identify) or a stand alone discrete unit like some cars and tractors used.
NOTE Anytime I went to get parts for an older IHC there were always questions of the serial numbers and codes or engine numbers and date of manufacture on and on and on lol. IHC was notorious for lots of modifications and changes even in the same model year grrrrrrrrrrrrrr it was always hard to get the right parts and know what was used... Even more reason NOT to know sitting here what ignition components you may have ????????????
THIS INFO CAN HELP DETERMINE WHAT YOU HAVE:
1) Ifffffffffff it has a ballast resistor (wire or stand alone unit) in series with the coil feed and its intact and works, if you turn on the ignition and good points are closed and all is correct and working THE VOLTAGE ON THE COILS INPUT would read around 6 volts (maybe 5 to 7 subject to ballast and battery and resistances) as that's the nominal operating voltage for a 6 volt coil.
2) Iffffffffffff you turn on the ignition points closed yet there's still close to battery voltage on the coils input, theres obviously no series V = I x R VOLTAGE DROPPING BALLAST. If your system is delivering 12 battery volts to the coil with ign on YOU NEED A FULL TRUE 12 VOLT COIL. If you used a 6 volt coil and applied 12 volts (IE no series voltage dropping ballast) the coil will overheat and the points burn prematurely.
3) Many vehicles that were 12 volt but used a 6 volt coil plus a ballast utilized a ballast by pass circuit ONLY WHEN CRANKING. That might be in the form of an extra I terminal on a starter solenoid (hot ONLY when cranking) or extra contacts on some saddle mount mechanical starter switches or other such devices. ONLY when cranking the ballast being by passed helped cold weather starting by momentarily applying more voltage to the coil. Then when running the series ballast was back in the circuit dropping around 6 volts so a 6 volt coil didn't overheat GOOD SYSTEM
Soooooooooooooo be sure and use the correct coil be it a 6 or a 12 volt. Again if your truck is supplying unballasted battery voltage to the coil under operation (IE no series voltage dropping ballast) YOU NEED A FULL TRUE 12 VOLT COIL NO BALLAST REQUIRED. HOWEVER if it has a working intact series voltage dropping ballast and delivers only 6 volts to the coil YOU NEED A 6 VOLT COIL WELL DUH LOL
NOTE in years of farming plus a used tractor dealer of the hundreds of old tractor coils I saw that were "12 Volts" or "12 Volts not for use with ballast" they had a LV primary (from + to -) resistance in the 2.5 to 4 ohms range and did not have any stand alone internal traditional "resistor" tucked away inside the can. Their 2.5 to 4 ohms resistance was comprised of the wire and coil windings alone IE no coil windings PLUS a separate internal "resistor", although a few older vehicles utilized such a coil that did have a separate "resistor" inside the can. I just never noticed those type of coils with a separate "resistor" inside the coil can on older farm tractors BUT HEY I OBVIOUSLY DIDNT SEE ALL THE OLD TRACTORS OUT THERE so maybe some used those coils ?????????? HOWEVER That may or may not be true for old IHC trucks I CANT SAY FROM HERE WHAT YOU HAVE !!!!!!!!!!!!!!!!!!!!
This may be more info then you asked or needed lol but hopefully it helps you understand and can figure out and buy a correct coil.
Post back any question
John T
Just curious - what year is this IH? I worked on several in the mid 70s that had the photo-electric sensor breakerless ignition. Many failed and I think that Holley/Prestolite "photo-eye" system got dropped after 1977. The breakerless kits we buy now use Hall-effect transistors. The original International Harvester used an externally resisted coil, just like the versions with points used.
John you were spot on, and I appreciate the information. Paragraph 2 was about what happened. I like you have been around ih stuff since the mid 50s , thing is this was a build that just like you said I knew nothing about what they used. I checked the coil input just like you said and I expected a built in resister wire. Replaced the coil and thing runs like a champ, get the brakes done and thing will be ready for the body shop. Been a fun few days. Thanks for all the replies guys. One of the poster mentioned about ih changing thing in mid stream, seems they used what was available at the time. Little know fact but there is one year of the scout production that uses an Olds side view mirror. Sure they bought them cheap . LOL
