1755 cyc location
Number 1 cylinder on any in line engine is aways at the front.
This can be a case of semantics.
The # 1 cylinder is generally but not always at the front of a vehicle. It is on the 1755.
I would say look for the water pump or water outlet and #1 should be that end, away from the drive end. Many forklifts have the engine mounted with #1 to the rear of the lift as the radiator is at the rear. Allis Chalmers Gs have #1 at the rear of the tractor. That is not to say there may not be a few odd balls numbered the other way.
What if it is J.I. Case cross-motor tractor…….?
Here’s a 2003 YT thread with an interesting tale about the discovery of a Case cross-motor tractor for all you guys that like those who pen a thread in the tractor vet style. However, this story contains zero self imposed back patting. :oops: Someone else is going to have to answer if it is right or left. Case cross-motor thread
I meant front of the engine I didn’t say front of the vehicle. By common conjecture the water pump end of the block is always the front no matter which way the engine sits in the vehicle.
