1937 John Deere BN
RHSfarm
I have almost finished restoring my first tractor. It is a 1937 John Deere BN. I put in a NOS block and pistons and a reman head. I had the carburetor rebuilt and purchased a magneto from a guy that rebuilds them. I believe I have the timing correct and the valves set but I cannot get it started. I can get a few pops out of it and then it's flooded. Any advice or help would be much appreciated.
post back with results of your check of spark, compression, and relation of the spark to the piston coming up on the compression stroke.
(quoted from post at 16:43:35 01/18/22)
I have spark on number 1 side when the LH impulse line cross the mark on the frame and spark on number 2 when the exhaust open mark crosses the mark on the frame. Ill check compression and let you know.
Other models of the 2 cylinder with mag would run with them either way. Ours did that for a time befotre we found out there was a correct way for that. The correct way I think gives a bit more power and a bit easier starting but they will run either way. Found this out back in late 50's.
I believe I have the timing correct. The flywheel side cylinder will spark when the flywheel LH Impulse line crosses the mark on the frame. It is also on the compression stroke. Then the pulley side will spark right after on the compression stroke. I'm waiting on an adaptor to check compression. I did get it to fire 3 times in a row this morning but then it seems to flood with no choke and I have to pull the plugs and clean out the excess gas.
(quoted from post at 18:09:23 01/19/22) I believe I have the timing correct. The flywheel side cylinder will spark when the flywheel LH Impulse line crosses the mark on the frame. It is also on the compression stroke. Then the pulley side will spark right after on the compression stroke. I'm waiting on an adaptor to check compression. I did get it to fire 3 times in a row this morning but then it seems to flood with no choke and I have to pull the plugs and clean out the excess gas.
drawing too much gas can be due to too much intake suction due to restriction. Do you have anything attached to the carburetor intake?
I have the air cleaner hooked up. It was cleaned thoroughly but Ill try starting with just the bare carb.
I finally checked compression. Only about 30 on each side.
The pistons and rings are new. Im worried I put the new
valves in the wrong spot. Exhaust to the intake side. Im
guessing this would cause low compression and hard
starting?
(quoted from post at 14:34:46 01/26/22) I finally checked compression. Only about 30 on each side.
starting?
I am not a Deere guy but I doubt very much that valves are interchangeable. However, it is much more likely that your problem is valve timing. If I were you I would review and check that.
I'll check into the timing of the valves. I can't imagine getting them put in wrong but I assembled it so long ago that I can't remember the steps I took. Thank you for the help.
