I have had my C for over twenty years and after replacing the clutch, radiator, and valve guides/seats when I first got it have had absolutely no trouble...until today.
I use this tractor for mowing (Woods belly deck) about an hour per week from April to October. Today it started right up after sitting all winter. I let it warm up and then drained the oil. I found two pieces of shiny metal in the oil drain pan. They are 1/2 inch long and appear to be gear teeth.
Since the tractor had been running fine and sounding ok I continued with my oil change, lube and fluids top off. Started it up and everything seemed fine. I made three rounds around my 5 acres and the engine started knocking.
I rechecked the oil and it was full. There is an oil pressure gauge mounted in the oil filter housing and at idle it was showing zero PSI. I increased throttle a little and the need moved ever so slightly. But the gauge is hard to see and I am not confident it works properly.
I parked it in the barn and drove home (property is 1 1/2 hours away) and got home and realized I didn't bring my service manual with me.
So I am looking for some input to think over before I go back over there and start taking things apart. I am guessing I need bearings.
1. Can the bearings be replaced by just dropping the oil pan?
2. What kind of gear is there that has 1/2 inch long teeth that would break off and land in the bottom of the crankcase?
