I think it would be better if you could share what issues you're having with your tractor.
My 3 point lift will only go about halfway up works fine otherwise then once in a while if it sits for days when u first start it it will lift all the way like it should it makes it hard to run the rototiller or corn planter as it won’t lift it high enough to adjust them right I just changed the fluid for the second time in two yrs and it lifted perfect at first start up then within 5 mins it went halfway and wouldn’t go back up
