1963 JD 1010
info
But do not weld on the rim with the tire on it ever. Very nasty life threatening explosions happen that way. Google Tire thermal Pyrolisis danger.
I am going to get a photo soon as I can I cannot are don't know how to resize on this puter I can do it on the shop puter. The tire is flat will not take air and sitting out behind his mom's in a shed.
The tire is coming off the rim no doubt about that I talked to his mom last night she is the cosigner and owner of the tractor. My time is free I don’t dismount are mount rear tractor tires : ) and I don’t have a problem paying for that.
I want the tire/rim off of the tractor. A SIDE NOTE I am sure he cut the tire and doesn’t want to admit it as to why I dunno. He ran the brush cutter till it tore the hitch out of the mounts I spec that’s how the tire got cut. I will be fix’N the cutter also.
A rant about this NO!!! He’s family I cannot motivate him no one can he’s my CUZZ I still love him.
Belongs to a neighbor. We need to get the power adjustable rim off to repair it; it has the outer weight what’s the best way to remove the rim/wheel.
one such (ebay)
The two bolts with nuts showing are the second step. the first is to support the 145# weight with a lift as I suggested before. To remove the rim/tire only, the jacks and drive clamps can be removed. The tire is likely filled, so lifting it with a crane/or hoist is also needed. To remove the wheel from the axle, which appears to be the nut in the center, may require a puller! Jim
