Marty13574
1974 MF-135, Gasser, Perkins AG3-152, 12v Negative Ground.
The only working gauge when I recently acquired was good oil pressure & coolant temp. I installed new voltmeter & new fuel gauge w/sender. Power lead from fuel gauge was connected to terminal #4 of external voltage regulator, so I connected new voltmeter '+' to same location. Cranked up and engine ran great and new voltmeter & fuel gauge worked, but voltmeter was reading 17 volts.
I removed battery and replaced external voltage regulator. When all back together, now no power to regulator terminal #4 so no reading on new voltmeter or fuel gauge.
I read about polarizing but wasn't sure how to do that or if it was needed.
Any help and/or advice greatly appreciated and thanks in advance.
