2019.05.14 Rust Pic
kcm.MN
Location
NW Minnesota
International B250, built at Bradford here in the UK from 1955 to 1962 I have the
49th and the 98th ones made with the C.A.V. mechanichly governed injection pumps and
large diff-lock pedals. MJ
I'm curious about this photo. Knowing nothing about this tractor, I believe I'm seeing daylight through the top of the motor. Are those the cyl head studs sticking up? Head is removed? Trying to make sense of this. Looks to be some kind of tank up there as well.
Looks like they removed the head and set the the valve cover on top of the studs to keep water out of the cylinders.
(quoted from post at 18:51:15 05/14/19) Looks like they removed the head and set the the valve cover on top of the studs to keep water out of the cylinders.
Yes that's how it appears. Probably got interrupted, they'll finish up the repair any day now.
