2022.08.06 "Extra" Pic
kcm.MN
Location
NW Minnesota
Puzzle: https://jigex.com/jLFDc
Ferguson TEF20 diesel tractor carring the 1955 Nottingham regestration number PVO 186 and painted
in the colors and letterd BOROUGH OF MANSFIELD WOODHOUSE and would have been supplied new by the
local Ferguson dealer James Windsor and Son Plough works Mansfield Notts. The implement in the
background is a hand operated root cutter made by Bamfords of Uttoxeter UK. MJ.
I'm glad you clarified the reason for the color. Also I think I see 4 fuel lines coming from the Simms (I guess) injector. Being a 4 cyl
on that size tractor is it a Continental engine? I had a couple of MF 35s and they were 3 cyl Perkins.
Hi Mark, Standard 20c indirect injection diesel engine with a CAV inline injection pump.Very complicated engine to rebuild as the conrods will not come through liners so you have to remove the crankshaft then fit the pistons with the con rods on into the liners then fit them into the holes in the block. MJ.
