251 mower New Idea
forsale
Hi just joined ;
Just purchasted a New Idea 251 Scickle Bar Mower -No Book- and when i get in heavy grass the clutch slips bad tryed to adjust but not helping . Is there a rebuild or solution and would parts be avaiable ? Just got a book from e-bay hasn"t come yet .
There's lots of reasons a sickle mower will slip. When the knife is on the ground is everything perfectly flat? The guards cannot be tilted so as to dig in. Heavy crop needs to be dry, if its really wet down under it is harder to cut. You may need to slow down your ground speed and keep your RPM's higher to get a good cut..drop down a gear. The knife needs attention, is each section sharp? The knife may have to be removed ans sharpened. A 4" angle grinder works like a charm to sharpen a knife. The leger plates in the guards need to be in decent shape as well..if the sharp serations are worn down you need to replace them. If the knife is sharp and the leger plates are good it should cut well. As for a belt slipping, the belt will have an adjustment on it to tighten it good and taut(tight) That should end belt slip
Dry Hay
Cutting bar level
belt tight
knife sharp
good leger plates
lube moving parts
That ought to get you going!
Hay thanks all that is fine this mower has a clutch inside a gear box that has a large spring and ball bearings that ratchet if things get tought and i think the spring has lost it;s tension and the addjust ment is as far as it will go . I am working on a soultion that i hope works for this 251 as soon as i try it i;ll get back on here .. thanks for the help i;m new on here and wow looks like a think tank for shure ..
