2510 will not run
Turn the ignition switch on, check for voltage at the coil + terminal.
Probably be 0 volts.
Start checking back toward the switch, likely will be the switch.
They have you covered below. Your tractor has ignition resister by pass through the starter solenoid so it runs on the by pass circuit but not through the resistor circuit.
