txbusmechanic
Hello everyone, I'm new here. I picked up a 2N recently and am in the process of fixing it up. One of the issues I am addressing is the PTO shaft seal, it's leaking very badly. So I went to pull the PTO shaft out, but it is stuck like Chuck. At first, I got it to come out about an inch, then I pushed it back in and tried again. It is out maybe 3 inches and it has stopped entirely. I don't want to damage anything so I stopped for now. The tractor obviously sat for a long time outside and there was a significant amount of water in the oil. I drained all the oil out of it, and I have the covers off where I can see the hydraulic pump. It's not excessively rusty, but there is definitely some corrosion. I believe that the shaft is stuck somewhere in/around the pump. I have been soaking the suspected area with PB blaster. My next move is to shove the shaft back in and then back out repeatedly until the rust gives up. I won't be able to work on it again until late next week, so I thought I'd come pick some brains on here in the meantime.
Anyone ever run into this issue? It would be nice if I could rig up a slide hammer to the end of the shaft but I don't know how exactly you'd attach that. Any advice would be appreciated.
