Nyquil Junkie
I read here all the reasons why they drift down... and its probably just in need of a good overhaul BUT... what I found odd was it only started doing that once I changed the oil in the sump. It was the typical milkshake slop. I let it drain for a good week.. maybe 2 as I got busy and didn't get back it. I filled it with 4.5 gal of TSC UTF. I took the dipstick plate off and it all looked fairly clean in there.
With the dirty old oil slop in it, the arms would stay up perfectly fine, with the weight of a small back blade on it. Once I changed it, it lifts fine, holds fine. Near the top of the travel it makes a strange gurgling noise, if you listen to it hard. it has no problem lifting my hillbilly counterweight (a backhoe bucket on a set of forks full of scrap... brake rotors, tire chains, old wheel weights...) probably 300-400lbs at least. it lifts more and faster with clean oil in it.
But now, ya shut the tractor off and over about an hour, it slowly sinks all the way down from its highest point.
I'm not overly concerned at this point, I can lift the counterweight and chain it up, and go about my business using the loader. At some point I might have to move some round bales with it but thats unlikely.
I'm just curious to know if this maybe is normal after an oil change, maybe air in the system? maybe removing all the crud in the oil took away its leak stopping ability.... :lol:
Does it drift down with the engine running and the pto on? I dunno, I didn't leave it sit running like that to watch it. I drove it around for about 15 min with it all the way up with that weight on it and it didn't seem to drop...I should have taken more notice of it.
But anyway... Just wondering if this happens when ya change the oil for some reason.
I'll have to take all the weight off it and see if it drops with just the rack on it.... about 100# worth.
