hello all, got my dads old 3020 running after i put on a 2nd hydraulic remote. hasnt been running good for a couple years now. i rewired the tractor minus the lights. has a new ignition switch with internal resister, 6v coil, points and condenser from roberts. it had a marvel schleber on it. i just put a zenith on it and rebuilt it with a comprehensive kit. my question is that after setting dwell to 31 degrees, after i remove the dwell meter it cuts out and either wants to die or just stalls. the ignition circuit has 2.2 ohms from the switch. ive not seen this before. coil b plus side is wired to distributer, tractor is wired positive ground. any one seen this before. thanks
