I have a 1966 4020 synchro range tractor. I have rebuilt the main hydraulic pump twice and then bought a new flow tested hydraulic pump from the jd dealer to fix the problem. But every time within five minutes of running the tractor the low pressure plastic return line from the front that dumps into the back of the tractor Ar34768 ruptures.
For some unknown reason it constantly ruptures 3/4 of the way down the line. There is no known obstructions. It passes fluid freely before running the tractor. I have even blown through the line prior to hooking it up from the upstream side and had zero restriction. Has anyone else seen this issue? Ive now blown 5-6 of these lines and nobody at the dealer can tell me what is going on. Any old boys have a clue?
