420 C engine questions
Am repairing a 420 C engine! Former owner ran with zero oil pressure and took out bearings on crank. Crank has been polished and still measures standard!!!! Pistons in engine were .040 oversize not .045 sold by J D. Question is did these foreign pistons cause failure? What is proper deck height so compression ratio is not too high? Are J D pistons made with flat top? (again affecting compression) Former owner bought crawler thar had been recently overhauled and I do not know history or where pistons came from. Any advice or comments appreciated
What does the cylinder bore measure? That would determine if the piston is sized correctly. If so, it would not effect the bearings going out. Pistons originally were flat tops. Don't worry about deck height. You won't get enough compression to hurt the thing. More is better in these little engines.
I think JD offered the pistons for those engines in .020 and .040 oversized. Wonder if the put the rear cam bearing in wrong ? Also look at the web of the block for cracks they had a problem with that.
If the cylinder bores were machined .040 over and the wrist pin height was anywhere near right on those pistons, I can't see how they could possibly be responsible for the engine failure.
Deck height? This is a relatively crude old low compression gas engine right? None of that stuff is critical.
Lack of oil pressure is what killed the engine. Improperly assembled with misaligned bearings, missing oil galley plugs, failed oil pump, run out of oil...
They are John Deere pistons, look inside the piston for markings?? Parts book shows a .040 piston-flat top.. Check out the oil pump, is it OK.. Or was the tractor run out of oil??
Recent overhaul and no oil pressure on a Dubuque = rear cam bearing installed wrong. If you don't have a manual that shows how to install the bearing let us know and I can post the instructions.
Pistons are fine as long as they fit the bore.
