I did a quick search, unless I missed something, saw results from a few years ago. Both couplers are leaking, good Deere ends. One started leaking fairly bad somewhere out the bottom near the tractor (cylinder will settle with that leak, leak opposite side where hose end is plugged in). Don't have creeping up or down while running (pressure up or down).
As with anything, I don't have much time to ...do much of anything. I haven't had many hydraulic issues in the decades I've been using tractors. Basically, I figure I probably need to take them off and put in a kit, at least o rings, but while I have them off, didn't know if I should do more for good measure (wear items). Does anyone have a good suggestion of a kit to order? Deere directly? Or aftermarket? Specific name/part number so that I am sure it has ~most everything? Thanks. My Deere dealer was bought out, don't know anyone there anymore, not helpful the last time I was there. I think my tractor is an '81 if that makes a difference.
I see something like this, but don't know about the place, or if this is "right". https://www.external_link.com/breakaway-coupler-ovrhl-kit-a-ar82570/
Also, it has the power beyond coupler. Where that hose screws into the top of the coupler unit, anyone know the plug size? The hose also leaks a little, I don't use it.
