430 T hydraulic pump issue
My 430 tractor adds hydraulic oil to the motor oil . The pump was previously “ rebuilt “ to correct this problem, but apparently didn’t. Any other possible cause of this to investigate before redoing the pump? Should I consider getting another pump instead?
The hydraulic pump is the only place hydraulic oil can get into the engine, I believe.
No, the only way to leak hydraulic oil into engine. Oring seal must have got cut. Or a bad shaft. Don't need another pump. Can be fixed, no leaks! Before you tear apart, make sure you can get your parts?
