dieselfume
Hey all, since my last post, I got a new trans pump put in the 4630 QR, and had the pto seals tested. tested good. they said the original pump was pretty bad. Also the pto lever on the LH side was busted up, so they replaced that. so, PTO problem has been fixed it seems- to the next issue. I have a growing puddle of hyd oil in my shop, it's leaking out of the back of the very LH remote. all the remotes have been converted to pioneer. this leak is pretty bad, I'm going to have to get it fixed- will Deere have parts to fix a converted remote? who will and can I do it at home without special tooling?
Next problem is the starter, it's a factory style delco that takes 3 or 4 clicks before it wants to give in and crank. I'm planning on converting it to a gear reduction starter, but don't feel like giving Deere $400 for them to get one for me. On the web there's alot to pick from with varying costs. Any of you know a good brand to go with? maybe some to look at and some to avoid? this tractor needs to be reliable, I'm using it twice daily for feeding.
Ideas?
DF
Ideas?
DF
