Hello Troy welcome to YT! Those Belarus tractors are assembled a bit odd compared to US convention. I
generally don’t recommend cobbling an electrical system to something other than as originally designed but in
this case it seems proper because the lights and heater blower are the biggest load you have on a tractor if
those are all coming back on line by connecting one fuse then I would say that is to much to expect out of one
fuse. There could also be problem that was caused when circuits got hot insulation melted and two circuits now
are unintentionally connected. You will need a wiring diagram to determine that or following suspect melted
wires back beyond the fuse block connections to see if this is an issue. If all else fails I would say it would be
proper to feed the lights and heater blower from new sources you create. If you go this route I would
recommend making the connection at the positive battery cable connection at the starter if it is fairly easy to
access instead of the battery to stay away from the corrosion from battery acid. Place a fuse holder there as I
show in the link and I would recommend the one with 10 gauge leads but should be okay to use 12 ga wire for
your added circuit feeds. Place it there so if something shorts out in the future along the run of the wire it blows
the fuse instead of possibly starting a fire. I would run a 20 amp fuse one for the lights an one for the blower.
Then if needed bump the amps up to 25 if it blows the 20 maybe even 30 but that will heat up a 12 wire pretty
good before it blows. You will need to run these feeds direct to the switches and disconnect the original feeds
or you will still be cross feeding between the circuits if the are all originally hooked together. To lessen any possible confusion the loop of wire on the example fuse holder is cut to turn it into two leads. Kind of long but
hope this helps.
Example fuse holder
