Glen in Iowa
Hard steering. Has always turned hard in my opinion. Oil supply to steering hand pump is 5 gallons per minute at 1100 rpm and 2150 psi. With front axle on the floor it takes 50-60 inch lbs to rotate the steering wheel the four turns stop to stop. Jack it up and it takes 25-35 inch lbs. This may not seem like much but it is a lot harder than you think. The hand pump has a new shaft seal and a new rotor seal sleeve torqued properly and rotates on the bench 9-10 inch lbs. While the tractor is in motion makes no difference. The rotor sleeve retainer for this application is 1.879 inches long. Will a different hand pump with a 25% shorterrotor make it easier to turn and increase the total rotation stop to stop by the same 25%? IH has never had (in my opinion) the greatest power steering. Of the many IH tractors that I have been around this is below average. Any ideas would be greatly appreciated. Happy and good new year to all.
