If you remember the PTO is in the disengaged position , but the PTO continues to turn. Can't move the stub shaft that is hooked to the rod that also goes to the clutch pedal. Stuck in the disengaged position..
A non Oliver guy suggested..... Put the tractor in gear and rotate the PTO shaft with a pipe wrench. Doing that the 550 tried to move forward as I rotated the PTO shaft. It finally broke loose and I was able to rotate the PTO shaft without the tractor moving ahead. Still can't get the PTO out of the disengaged position. The PTO turns while the tractor is running...
WHAT ARE YOU FELLAS THOUGHTS?????
