620 IH Drills
Good old drills the hitch is built light and the box will eventually start to crack at the bottom where it meets the drill frame other than those two things and if the press wheels are in good shape they?re are a great machine . Farmed with two of them on a tandem hitch from new in the 70s until about 20 years ago
Yes but it doesn?t happen unless it?s way to wet because the shaft the casters bolt to keeps dirt from building up between the wheels
I have a differant experience than that, it builds up on the inside and rubs and will ruin the tires if you don't clean it out, to make matter worse the the tire valve is on the inside, the wrong side on that application, just a blatant abuse of power by the engineer's.But other wise it does have some nice features. The Grease bank on the rear is or was overdue!
I?ve never had that Happen can you turn the wheels around so they?re wider apart it?s just an implement rim so it should be reversible but there isn?t a lot of room in between the hitch
