We have two 66's and one 90. One of the 66's and the 90 both got pulled just about that far (120 km). Not a big deal in either case. Go slower and stop a few times with the 66 and grease those bushings. The 90 has tapered roller bearings, so it was dandy and I could go a little faster. But as mentioned above, also dependent on what roads and traffic are like in your area. For me it wasn't great - especially as I had to pass right downtown through three fairly substantial towns. But not impossible. The last one I pulled was the 90, about 12 years ago. Of course, drivers around here have only got stupider and more aggressive since then. The left-hand cut is a bit of a pain - drive as close as you can to mailboxes and road signs and that's as good as you can do.
I didn't use an offset hitch, although I later built one since I was regularly towing old/oddball/offside equipment around. You have to be really careful when building an offset hitch: A lot of people just don't get it and think you can just stick a tube out sideways from your receiver and weld a hitch to that. Remember that with a regular hitch going straight into your receiver, there's zero moment/torque on that tube/hitch/frame. None at all. Not matter how heavy your load is. But if you weld up an offset hitch so it's taking the tongue two feet off to the side, and if you have something with 250# of tongue weight, suddenly you have 500 ft-lb of moment/torque on your receiver, vehicle frame, and whatever tubes & welds you've put together. Then consider that every hard bump probably gives a momentary impact loading of four or five times that, and suddenly you realize that's a holy heck-load of torque/stress on your home-brewed hitch, receiver, and frame. If it twists apart and goes into oncoming traffic, the relevant authorities are going to be pretty critical of any home-brewed contraption. For this reason I wouldn't use an offset hitch for anything with any substantial tongue weight, and the one I built has some pretty heavy gussetry and is only offset 12". And I haven't used it since we got rid of our larger pickups. I just don't trust the hitch or old/rusty frame on any of my half-ton pickups that much. The good thing about All-Crops is they have almost no tongue weight, so you'll probably be ok regardless. But if it were me, having towed both a 66 and a 90, I wouldn't bother with the offset tongue. If the road gets narrow enough at any spots that the extra foot or so you'd gain from an offset hitch is necessary, I'd rather just stop and wait for a gap until there's no oncoming traffic. From what I remember of towing ours however, they weren't wide enough that I was causing too much grief, as long as I was driving the truck fairly far over to the right.
Before you buy it however, consider if you really want an All-Crop. I'm sure folks on here are sick of me writing this as I've said it many times. But even though we own three All-Crops, having now been around or used many other similar pull-types, the All-Crops would be at the bottom of my preferred pull-type combine list. I'd take (probably in this order) an IH 80/82, Oliver 18, Cockshutt 422, or Deere 12/30/42 over an All-Crop. The Deeres might move up a couple spaces depending on what I was using it for: I like the Oliver and Cockshutt's better, but the Deeres are nice for regular use since cutterbar components are so easy to come by.
The All-Crops were everywhere back in the day, because they were cheap enough to bring combining ability to everyone, and the rubber concaves allowed them to thresh every crop type. But they were light, flimsical, gangly, awkward, and plugged easier with the small diameter cylinders. And for any standard grain/cereal, regular steel concaves would be just as good as the rubber. Probably better these days, because at this age most of the rubber in those All-Crop concaves has worn excessively. You can find new rubber for them (I had some cast for my 90 out of high-durometer urethane), but I'd certainly prefer regular steel concaves for anything I'm doing. And if I was looking for an All-Crop, I'd strongly prefer a 72 or 90 to avoid the canvases.
But if it's accessible, cheap, in great condition, and nothing else is available, it will probably do fine for you. It wouldn't be my choice though.
