706 Farmall
I am looking for clarification on a Post that the Tractor Vet posted December 2 2012? I am working on a 706 Farmall 1964 with a TA. The question in Reference to Adjusting Clutch and Dump Valve adjustment? The Tractor Vet states to Hold the transmission Brake lever back against the gear and adjust cleves so that the pin will slide into the hole? What is he meaning when he says hold the transmission brake lever back against the gear? Is the Brake Handle up or down all the way? He also states to adjust the dump valve by turning in the adjusting bolt until the light comes on? Is the tractor needing to run at a certian RPM? My light is on at low RPM? And when the helper is holding down the clutch, I have no pressure at the MCV.? I get about 20 PSI when the clutch is released at the MCV. I mounted a pressure gage on the side so I could monitor pressure? Any Help or Clarification would be Greatly Appreciated. Thanks
