LarryMaine
Am rebuilding my lift cover & cylinder. Have replaced pivot pin, cylinder piston and washer and O ring. Replaced all o rings. Removed and cleaned control valve, replaced relief valve. Will measure and adjust clearance for draft and position control. I removed the check valve plug on side of lift cover, and check valve components should have just come out, but they are stuck in place and it does not move at all. Not talking about the valve seat, I mean the check valve pilot assembly, ball, spring, etc. that are in front of the seat. Any suggestions on how to get it out without damaging it (replacement check valve parts are not available anywhere). Thanks all, Larry.
