Hi all,
still battling and learning about cooling on the 880 gas as it is still running hot this spring. I got the shop manual and learned:
1. Radiator should be full to 1.5 below bottom of filler neck
2. I have a non-pressurized radiator. It should be a pressurized system on the 880 (per manual)
2. I have the 'Standard-Thompson' thermostat, with the separate shell and 3/16 thick rubber ring that sits on top...
Some thermostat shells must be oriented to enable the right flow, is this style with the shell one of them? I don't recall seeing a 'FRONT' stamped on it.
Then the other question is the correct sequence of assembly...is this right?
-Place flat gasket on lower water housing surface
-Place thermostat over the gasket
-Place shell over thermostat
-Place 3/16 thk rubber ring over shell.
-Bolt down upper howsing.
Thanks for the help as always.
