Generator had new field coils installed and now doesn't charge. If the ends of the field coils are connected backwards, would that stop it from charging?
When bench testing w/case connected positive, when applying negative to armature (A) connection the unit motors same direction as on the engine, if negative is also applied to the field (F) connection the motoring slows down. Any and all help much appreciated. FWIW there is also a new voltage regulator.
Ken
Ken
