I posted here back in early February as I was having problem with my steering on 1952 model 8n. I was able to take the entire steering assembly off the tractor to have someone repair it if possible. The issue I was having was the steering wheel was free spinning which indicated that maybe it was a steering shaft and nut box problem. Sure enough the nut box had broken and the ball bearings had all come out through the tubes that are bolted to top of nut box. I ordered a shaft and nut box assembly part number 8n 3575B. When my mechanic was getting ready to install it he noticed that the spiral with the nut box attached was about 1 inch or more shorter than the original shaft. The total length of the new shaft is same length as old shaft but the spiral on new one is different. Also the width of the spiral bands on new shaft is narrower than old shaft. He tells me this will not work. This was aftermarket shaft and looks like every other after market shaft I have looked at. Has anyone got any suggestions? The photo shows the difference of the two shafts as I described. My tractor has serial 370496- later model.
