I'm trying to save money by not buying another alternator. It quit charging so I took it apart. One possibility is there was no continuity between a brush and the small wire terminal. (Not sure if there's suppose to be with it not running) I attached a jumper wire going out but when I wired it to the small wire it still didn't work, but when I attached it to the big battery terminal it did work. I left it charge for awhile like that and alternator was too hot to touch and was smoking a little, does a alternator normally get hot? Now the alternator works as it should without using the jumper wire, but not sure if it will still overheat. Also I figured it was too hard to put a plastic plate back in so not sure if that's important. Also I believe I mounted the back part 1 hole off or 120° but don't think that would matter.
