931 case pto shaft
gene pesch
On a 931 case what kind of ajob is it to replace a broken pto shaft? Everything seems to be o. k. but shaft is broken. Thank You!!!! Gene
If this is a CK with DOM 3pt. It's pretty easy. Remove drawbar- remove bolts suporting drawbar support bracket and let it swing down. Drain trans. 17 gal. Disconnect pto lever from splined shaft, remove all bolts from housing and pull it away. Broken shaft does not allow you to put a peice of pipe over it to balance the housing so removing it may be aukward and the hyd pickup screen could be damiged if not carful.Once the PTO housing is removed you need to remove the inner casting suporting the front of the PTO gear train and replace the shaft. A 4hr. job for an experienced tech.
