Broken S Ranch
I have a 9n that had a posits too all hydraulic system installed before I bought it. I backed into a hidden stump a few weeks ago engaging the protective spring, which lifted the deck off the ground. After some tinkering with it I was able to unstick the top spring and went back to mowing. Next time I used it, the hydraulics would lift but only while the pto was engaged. Once you pushed the clutch the load would drop. Shortly thereafter it quite working all together. I have replaced the hydraulic cylinder and piston (the old piston ring was bad). This did nothing. I then replaced the control valve and the safety release valve. That seemed to fix everything... for approx 20 minutes. I parked it until this morning. Went out to use my fixed tractor to mow this morning and now the hydraulics wont lift at all again. I becoming quite frustrated. I have to be missing something... probably stupid. The forks are connected, the pump is churning the hydraulic fluid, and the valves and cylinder itself are all new. What am I missing? Please help! Thanks!
