f really important, the tire manufacturer would mark the side wall with arrow and words, just like a tire I bought 3 weeks ago..(quoted from post at 13:05:49 07/20/21) Just my view, but, this sounds to me like this is an incorrect assumption that rubber belts are akin to rubber tires. When first introduced, the rotational pattern of radials was different from bias ply. While that was due to the tread design/pattern, some ascribed it to the tire composition. This sounds like that to me.
or 'non-directional' tires, the direction of rotation does not matter, radial or biased & most are 'non-directional',& fine to change direction at time of rotation, but.....and there are always the exceptions to every generality. There are "directional" tires & with those, it does matter. One example are studded winter tires....and there are others, too.(quoted from post at 14:46:39 07/20/21) I think the thought of tires, especially radials must always rotate one way is a myth.
The forces on the tread versus carcus and belts, etc. is equal between acceleration and deceleration.
Therefore it does not matter which side the tires were placed or how many times they moved to the other side.
I can imagine the fibers holding the vbelt shape could orient somewhat to resist the stretching due to traction at the surface.
Flipping belt over would maybe cause the fibers to then migrate in the opposite direction.
The result being the fibers have migrated twice as far from their original position.
(quoted from post at 17:47:36 07/20/21)or 'non-directional' tires, the direction of rotation does not matter, radial or biased & most are 'non-directional',& fine to change direction at time of rotation, but.....and there are always the exceptions to every generality. There are "directional" tires & with those, it does matter. One example are studded winter tires....and there are others, too.(quoted from post at 14:46:39 07/20/21) I think the thought of tires, especially radials must always rotate one way is a myth.
gree with all you said.(quoted from post at 17:29:48 07/20/21)(quoted from post at 17:47:36 07/20/21)or 'non-directional' tires, the direction of rotation does not matter, radial or biased & most are 'non-directional',& fine to change direction at time of rotation, but.....and there are always the exceptions to every generality. There are "directional" tires & with those, it does matter. One example are studded winter tires....and there are others, too.(quoted from post at 14:46:39 07/20/21) I think the thought of tires, especially radials must always rotate one way is a myth.
True that. There are also tires that are to be only placed on the left or right. Usually a high performance rain tire.
My post was about internal tire materials and construction "movement" of those materials.
