AC lift cylinders.
Can anyone tell me where to get kits for the lift cylinders on a 185?
Three-point lift or a loader? If three-point the AGCO parts books show a serial number break, so you need your serial number to look at the right ones. In the early 180/185 book it appears several cylinders were used so you need to ID yours. They might be the same in the later 185 book, I didn't research that, you can if needed to match your serial number. An AGCO dealer should have or be able to get the parts. There are other sources you can find searching part numbers.
Parts books for 185
If you are looking for loader lift cylinder info You need to ID the loader. Many different loaders could be mounted on a 185.
