Kelly in tx
I park four old tractors under a lean-to or shed roof of about 15' by 40'. I park the tractors side by side so front to back of each tractor uses the 15' space. I want that roof to be longer to better protect the tractors from sun and rain. The rafters are 6 C purlins. The edge is 4 C purlins. The roof is corrugated galvalume. I want to extend the roof by two feet. I intend to just remove the last row of sheet metal screws, tuck the new corrugated galvalume under it and replace the screws.
The bottom of the 4 C purlin clears the exhausts of my old tractors by about 4. The parking area is dirt (gravel/caliche), not concrete. The ground slopes downward away from the parking area.
I can: 1) put on 6 C purlin and extend the roof flat (I'll have easy exhausts clearance) or
2) put the 6 C purlin at the same angle as the rafters (I might have to remove a tiny bit of ground sloping away from the parking area.
What would you do?
What would you do?
